Build sticker?
Old Feb 16, 2013 | 12:58 PM
Hairy Eagle's Avatar
Hairy Eagle
Default Build sticker?
Hello all....
New to me 1998 B3500 5.9--I know where the tire pressure/MDH sticker is, but have had no luck finding any build information sticker (Listing trans version, rear ratio, paint code, etc). Checked all the door jambs, glove box, etc...no joy.
Did find a small computer box bolted to the floor beneath the drivers seat--ABS module?
Thanks,
Geoff
Old Feb 16, 2013 | 01:34 PM
familytruxter's Avatar
familytruxter
mine was on the bottom side of the hood, but mine is a '93 not sure if that helps you.
Old Feb 16, 2013 | 02:11 PM
blackvan's Avatar
blackvan
Old Feb 16, 2013 | 02:30 PM
Hairy Eagle
Awesome!
All was there under the hood.
Thanks guys.
Geoff
Old Feb 17, 2013 | 09:01 AM
rsdata's Avatar
rsdata
Default if you have a new to you Dodge Van
I picked up an '01 B2500 van about 18 months ago. I found a post from Stev very helpful in going through the van and doing maintanence and preventive stuff to keep her on the road. The thread I am refering to can be found here:
https://dodgeforum.com/forum/dodge-r...rovements.html
Don't hesitate to ask questions on this forum... these guys are GOOD!
Old Feb 17, 2013 | 01:37 PM
dakotaff's Avatar
dakotaff
Originally Posted by Hairy Eagle
Hello all....
Thanks,
Geoff
You can request a build sheet which contains all of the original information at the time of it's build.
They'll get back to you fast.
Dodge Build Sheet request
Old Feb 18, 2013 | 08:21 AM
Hairy Eagle
Very useful post, some seriously good information. Thankfully the previous owner had load range E tires installed about 5k miles ago--though only inflated to 35 psi.
On my first extended drive I went a bit too quickly over a frost heave... A few miles later, pulled over and shut it down to make some calls, and smelled acrid burning plastic. A quick check found nothing, but a few hundred feet after getting underway again the MIL tripped--0138. I'm thinking the O2 wires hit the cat after my Dukes of Hazard jump.
Geoff
