A/C Delete
Old Mar 1, 2013 | 05:20 PM
Hairy Eagle's Avatar
Hairy Eagle
Default A/C Delete
Howdy,
I'm planning on pulling my compressor, condenser and lines--from the belt routing diagrams I find online it looks like all I'll need is a shorter non-A/C belt. Correct?
Thanks,
Geoff
Old Mar 2, 2013 | 09:09 AM
Rusty93RamVan's Avatar
Rusty93RamVan
Correct
Old Mar 2, 2013 | 02:06 PM
Hairy Eagle
Awesome!
Thank you,
Geoff
Old Mar 2, 2013 | 07:23 PM
moe7404's Avatar
moe7404
some where i saw a kit with a plate and pulley. still uses the stock length belt. cant remember where. check out http://www.hughesengines.com/ dor34178
Old Mar 4, 2013 | 10:57 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Why run the pulley when you can use a shorter belt?
Old Mar 5, 2013 | 10:17 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
For one you can run the OEM specified belt for non-A/C models, instead of having to keep track of a custom sized belt. Secondly, using the pulley prevents too long of a span in the belt where the A/C pulley should've been.
Old Mar 5, 2013 | 07:49 PM
Mobile Auto Repair
On my van's belt routing diagram under the hood it show the optional route with no AC compressor. And I am always asked if the van has AC when I am ordering belts for them. So there is the optional belt already in Chrysler and the part store's POS system.
Old Mar 5, 2013 | 11:42 PM
stev's Avatar
stev
Accessory serpentine belt routing-3.9L, 5.2L and 5.9L gasoline engines. If you have a Magnum engine ...
If you look under the tiny hood, there is a sticker that shows the belt options ...
Old Mar 23, 2013 | 10:53 AM
bluemalibu's Avatar
bluemalibu
Good luck getting this belt. I have been trying to order this for a 1994 ram 5.9 and they one that shows up is LONGER than the belt used with AC.
If anyone has succeeded please share the part number.
Parker
