dodge van 3.9l v6 problem failed
Old Mar 14, 2013 | 04:06 PM
jerome13's Avatar
jerome13
Default dodge van 3.9l v6 problem failed
hello
I am French escuser please me for any writing
I have a dodge van b 250 3.9 liter v6 that has failed when I ride the cylinders turn off
I changed the injectors, sparks plugs, ignitor, the fuel pressure regulator, and that continuous
could you help me please
thank you in advance
jerome
Old Mar 14, 2013 | 05:10 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Please explain the statement "cylinders turn off."
Old Mar 15, 2013 | 03:22 PM
jerome13's Avatar
jerome13
when the engine is running I run the 6 cylinders and then 5 then 4 cylinders ... I do not know if it's the fuel pump or ignition problem
Old Mar 16, 2013 | 02:22 AM
alloro's Avatar
alloro
Replace the ECM (Engine Control Module) computer.
Old Mar 17, 2013 | 10:30 AM
jerome13's Avatar
jerome13
often happens on these vehicles? you have a website where I could find a used ECM? thank you very much
Old Mar 17, 2013 | 02:09 PM
alloro's Avatar
alloro
Are you in the USA, Canada, or France?
What year is the vehicle?
Post the number from your existing ECM and we can help you locate one. The number will end with 2 letters like AA or AB, etc.
Old Mar 21, 2013 | 08:25 AM
jerome13's Avatar
jerome13
hello is it possible to run after the bioethanol?
Old Mar 21, 2013 | 07:08 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
What percentage did you fill the fuel tank with? Here in the United States we are forced with 10 percent ethanol to 90 percent gasoline/petrol. These vans can run with that but should not be ran with any percentage higher than that and definitly not on pure ethanol.
Old Mar 22, 2013 | 03:10 AM
jerome13's Avatar
jerome13
if I put a case ethanol is that I can ride at 100%?
Old Mar 22, 2013 | 08:42 AM
Mobile Auto Repair
Pure ethanol in these engines are bad. These engines were not built to run on pure ethanol or high concentration of ethanol.
1 liter ethanol to 9 liters gasoline/petrol is the most that you can use.
