Van pulling when apply brakes hard
I have a 2000 ram 1500 van I have recently replaced both calipers and brake hoses. And also had the rotors turned and I still have the same problem! When have to do a hard stop van wants to pull to the left. This is why I replaced the brakes but the problem is still there any ideals what could be wrong
inspect and adjust rear brakes.
Inspect strut rod bushings. They wear from the inside out and can appear fine but are all tore up inside.
These bushings are on the bar that goes from the lower control arm to the frame bracket behind the suspension.
Having a lot more weight on one side of the van than the other can cause pulling no matter what you do to the brakes.
Well guys I've fixed the van I have deleted the abs system all together proportioning valve was 216 from dodge and the metering valve was 330 both parts are only available from dodge so I've put a manual adjusting proportioning valve in and have replaced both caliper hoses and all lines that needed replaced and everything is running great
Trending Topics
