the dreaded no bus
Old Apr 2, 2013 | 01:11 PM
rebelsurveyor's Avatar
rebelsurveyor
Default the dreaded no bus
Tried to start the van a little while ago and it turns over fine but doesn't start. After few tries I noticed the no bus briefly in the odometer window. After some research on this forum I tried removing the negative batt wire and turning the key on and waiting 10 minutes with no change. I pulled the connectors to the pcm but don't have the recommended CRC spray, will WD-40 do? Don't have a meter to check the ASD fuse but will get one if it's necessary. Any other suggestions before I buy a new pcm? It's a 2001 by the way. Thanks in advance.
Old Apr 3, 2013 | 03:58 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
No, do not use WD-40 on electrical connections.
Old Apr 3, 2013 | 08:54 AM
rsdata's Avatar
rsdata
Smile electrical contact spray solution
I do a lot of electronic work and have found this contact cleaner spray works wonders.
http://www.mcmelectronics.com/produc...D5S-6-/200-040
from MCM Electronics near Dayton, OH
search Deoxit
if the link above does not work.
They ship out fast if you order online or call the 800 #
Old Apr 4, 2013 | 09:17 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Also check the fuse that powers the PCM before replacing the computer.
Old Apr 5, 2013 | 01:41 PM
rebelsurveyor
Thanks for the help guys. Went ahead and ordered a new pcm and just installed it and it works fine. The brick is back on the road!
