No start, No spark
Old Apr 8, 2013 | 06:12 PM
ejlowe's Avatar
ejlowe
Originally Posted by alloro
Sometimes you can find good used ones for 1/2 that.
How can i get one cheaper, used, with what needs programed? or am I able to use a used one without having someone program it? Also, should i worry about the ignition?
Old Apr 9, 2013 | 01:30 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
As long as the numbers on your's matches the replacement used one, then it's an even swap with nothing to program. There's an 8-digit number on the PCM that ends with 2 letters, like AA, AB, AD, AE, etc. That number and the 2 letters are what you need. Post the number here and maybe we can help you find a used one.
Old Apr 9, 2013 | 09:09 PM
ejlowe's Avatar
ejlowe
PIN 56040389AP
I seen one for sale that had same # except the last letter is an "E". Would this work? if not, then I am still on the hunt.
Also, i belive i read on this forum that you can burn VIN and mileage with a OBD3, If thats the case, will i still need to match #'s?
Old Apr 9, 2013 | 09:34 PM
alloro's Avatar
alloro
I've never seen a number end in AP. Are you sure it isn't AB or AF?
Which engine do you have in this van?
Old Apr 9, 2013 | 11:10 PM
ejlowe's Avatar
ejlowe
You're right,... there is a software upgrade sticker over the original #'s. It was hard to make out last letter but it looks like a P or an F.. Never the less, I peeled a little bit of the sticker away to get a look at the original label and the PIN # is 56040389AB ... Does the last letter have to match? Motor is a 318
Old Apr 9, 2013 | 11:28 PM
ejlowe's Avatar
ejlowe
Just to clarify, the software label was completely covering the original PIN.. the hand written PIN looked to be a "P" or possibly an "F"..
Old Apr 10, 2013 | 06:25 PM
ejlowe's Avatar
ejlowe
From what i gathered today, the software sticker can have a different PIN? If thats the case, the dodge programmer needs to write a little bigger :-/I need a digital camera.
Old Apr 10, 2013 | 08:48 PM
alloro's Avatar
alloro
Check with this place, they have one listed at http://www.car-part.com for a 2000, 5.2L 1500 Dodge Van for $75. They did not list the PCM number so I can't verify it's the right one.
Brunswick Auto Recycling LLC
117 Bath Road
Brunswick, ME 04011
Phone: 207-725-4199
800-277-4199
Fax: 207-725-5262
Old Apr 11, 2013 | 08:40 PM
ejlowe's Avatar
ejlowe
Great thanks alloro! I will give them a call first thing in the morning.
Using the heat was a great idea and I thank you. I have used a hairdryer to make sure my ignition module was bad on my motorcycles. Start and run the bike, put heat on module and if it shuts off, its bad.
Thanks for your help and will let you know how its going.
