'99 3500 Van was running fine, now won't crank "no bus"
Old Jun 3, 2013 | 09:54 PM
JeremyWeaver's Avatar
JeremyWeaver
Default '99 3500 Van was running fine, now won't crank "no bus"
First time posting. I have a 99 dodge ram van 3500 with a 5.9 gas engine. It was running fine until one night i parked it. Next morning it wouldn't even crank.
The battery is good. Gauges come on when i turn the key on. (sometimes they work sometimes they don't, but it was doing this before). Starter is good (i had it bench tested.) I can here the fuel pump engaging when i turn the key on. I Here the fuses click. But no crank. I don't see any obvious frays in wiring harnesses, (i could check that more thouroughly.
Sometimes when i turn the key on i get a "no bus" message on the odometer.
I've been doing some reading on this forum and others and I understand it could have something to do with the pcm/ecm, crankshaft sensor, short in the wiring, etc.
I need help diagnosing this guys. Shower me with knowledge.
Old Jun 3, 2013 | 10:07 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Replace the neutral safety switch down on the tranny.
The No Bus message indicates a loss of communication between the instrument cluster and the PCM. 9 out of 10 times it's the PCM going bad.
Old Jun 3, 2013 | 11:22 PM
JeremyWeaver
so, I tried starting it in neutral and it started fine. Won't start in park only in neutral. Does this mean it's the neutral safety switch?
Old Jun 7, 2013 | 10:14 AM
alloro's Avatar
alloro
It's either the switch or the cam inside the tranny. I'd try a new switch first instead of opening up the tranny.
