A/C issues
Old Aug 12, 2013 | 12:26 PM
gertie240's Avatar
gertie240
You said the system would not take any more refrig. when you tried. Did you have the a/c on max cool and was the compressor running when you tried? It does make a difference if the compressor is not on,
Old Aug 12, 2013 | 01:15 PM
Tommy555's Avatar
Tommy555
I did have the A/C on full blast when I attempted to add more refrigerant and I'm pretty sure the compressor was going at the time. I brought back the can after I realized that I didn't need it, so I'll have to buy another can if I want to try it again. For what It's worth, I did some driving just a a few minutes ago and it's still the same - the A/C blows kind of hot at idle.
I ended up driving to a shop and asked how much he would charge me to diagnose my A/C problem. The mechanic said he'd charge around $50.00 which could be worked into the price of the repair if I let him fix it. I'm not really ready to spend any more money on the A/C right now unless I fix it myself, so I'll have to wait until I'm ready to fix the problem before I let him diagnose the issue and then go from there.
Old Aug 12, 2013 | 02:41 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by Tommy555
When I took the old fan clutch off I compared it to the new one. I turned both of them by hand and didn't really notice that one was any harder to turn than the other, so I have a feeling that there was nothing wrong the original clutch at all.
Actually I would've done this prior to removing the original one. Being the same I probably would've returned the new one and moved on to something else.
Old Aug 12, 2013 | 02:59 PM
blackvan's Avatar
blackvan
Old Aug 12, 2013 | 03:14 PM
Tommy555's Avatar
Tommy555
I actually did try to move the original clutch by hand before I started to take it off, and it moved very easily when you try to spin it from the fan blade. I would have never been able to compare that to trying to turn the new clutch directly from the center thread. I would have still gone ahead and replaced it.
Originally Posted by blackvan
When my fan clutch was starting to go bad the only symptom was the same as yours, poor AC performance. My engine was not overheating and the fan clutch I removed still seemed fine when "tested" by turning it by hand.
Test it in traffic then you'll know. The performance of this undersized R134a system at idle will always be somewhat less than at speed of course, but it should be tolerable.
Yeah, I tested it while idling in traffic, the A/C was just as hot as it always was. Someone I recently talked to said that it would be entirely possible that the new fan clutch could be defective from the manufacturer and that it could be the cause of my issue still. I think it might be time to stop guessing and just have someone look at the truck pretty soon.
Anyway, I've read that I can make sure that the clutch is okay by trying to let something rub against the fan while the engine is running to see if I would be able to manually stop it from spinning. If I can do this safely and it stops, that would indicate that the clutch is bad. If I am unable to stop it, the clutch would be consider good. Does this make sense to you?
Old Aug 12, 2013 | 04:21 PM
blackvan's Avatar
blackvan
Old Aug 12, 2013 | 05:08 PM
Tommy555's Avatar
Tommy555
Or course, I wasn't going to be stupid about it (though some might say the very idea of doing this can be considered as stupid on its own), but if I can get some cardboard to stop the fan, that definitely could have told me something about the clutch. I would have known pretty quickly if the fan wasn't going to stop.
Old Aug 12, 2013 | 05:26 PM
blackvan's Avatar
blackvan
Old Aug 12, 2013 | 05:44 PM
blackvan's Avatar
blackvan
Old Aug 12, 2013 | 06:20 PM
gertie240's Avatar
gertie240
Tommy, please don't try to stick something into a moving fan!
And what part of the U.S. do you live in ? I think even the local Midas shop is doing free a/c checks. Could you maybe push a meat thermometer through the front fins of the rad. to check its temp. at idle? Also if you attempt the a/c repair again, spring for one with the gauge . fill on the low side port. I haven't heard of one not being able to take some charge. Follow the directions on the can , usually something about shaking it, and turning it 3 to 9 and back.
