will an '89 roof fit my '73 van? I want a hi-top
I found a nice high top roof on a 1989 extended length van in the junkyard. I want to put it on my 1973 maxivan. I haven't fine the measurements yet but does anyone know if it should fit?
Also, if you have any advice on installing it, I would be interested.
I don't know the dimensions of the '70s Dodge vans but I remember them as being a lot wider than my 2000. Exact fit? No. Can you make it fit ? Sure, maybe
The external dimensions for 2nd and 3rd gen Dodge vans are on the wiki page.
http://en.wikipedia.org/wiki/Dodge_Ram_Van
Thanks. Too bad they don't have the 1st gen dimensions there. It did mention that the 2nd gen had a longer rear extension. If the width is close enough, I'm sure I can make it fit for sure (maybe).
Looks like it's off to the junkyard with a tape measure.
You must ask your question in the proper forum.
Home of the
'71-'77 Mopar B-Van Forum
http://moparbvans.proboards.com
Typically they can answer anything about your van era and a some info up to the 1983 era.
Home of the
