fuel pump float does not work properly
Old Feb 2, 2014 | 10:41 PM
k2nepal's Avatar
k2nepal
Default fuel pump float does not work properly
I have another issue, the fuel pump float is not working properly, did drop the fuel tank, took out the fuel pump, seeing fine, put it back into tank, now the float is acting up, does not come down, when the ignition switch is off. Do I have to replace the whole unit? I have the feeling that I have to drop the tank and take a second look at the unit. Any advice.
thank you, and be safe.
