Distributor rotor shaft
Old Mar 13, 2014 | 10:40 PM
funair02's Avatar
funair02
Default Distributor rotor shaft
Hi all...
I did the yearly plugs, wires, cap and rotor and noticed something. The distributor shaft has about 1/4 of play if you take your hand and try to turn the rotor manually. I know it wont and shouldn't turn but is this play within spec?
Thanks!
Old Mar 13, 2014 | 10:51 PM
blackvan's Avatar
blackvan
3/16" is the max allowable play at the end tip. I think you can measure it precisely with an inexpensive caliper. I have one of these and so far it has worked well for me.
http://amzn.com/B0002JFMIO
The distributor bushings are known to wear out on these engines.
