wiper intermittent control module
Old May 18, 2014 | 09:20 PM
gly-phen's Avatar
gly-phen
Default wiper intermittent control module
I have a 1996 Dodge B2500.
i need a heads up on whether the wipers will park at the bottom if i turn the wiper switch to off somewheres on the downstroke, if the intermittent control module was/is no longer hooked up.
i accidentally damaged the terminal in the number 4 cavity of the connector (blue wire). i do not think the module is going to work anymore after that. i do not want to make any attempts at fixing this either.
high and low will still work as well as the washer pump? keeping in mind the multifunction switch is just fine. The van is currently not running as i am wiring something unrelated to this right now.
Is there a wiring diagram just for the module's circuit?
thanks guys, i appreciate it!
