My van thinks it's a bronco
Old Jun 12, 2014 | 09:58 AM
Red36's Avatar
Red36
Default My van thinks it's a bronco
I have a 2000 ram van 1500 5.2. 150,000 miles. When driving between 35 and 50 mph engine bucks and chugs hard. Engine light not on. Could someone please help? Thanks
Old Jun 12, 2014 | 04:30 PM
Dennisa.taylor's Avatar
Dennisa.taylor
I have a 2000, 5.2 with 109,000 miles on it. It was hesitating and cutting out when warm. I did tune-up, plugs, wires, coil, distrib cap & rotor to no avail. I was getting ready to check fuel pressure for possible fuel pump problems. I installed an upstream oxygen sensor(NTK)and it runs like a new van. I wasn't aware that the oxygen sensor would cause that many problems. It was an easy fix.
Old Jun 21, 2014 | 01:08 PM
fursail's Avatar
fursail
I had the same problem with my 1994, changed out all kinda parts, that were needed, like tune up stuff. In the end it turned out to be a sticky kickdown cable. After a bunch of wd40 and working it to make sure it moves freely. I drove around with the doghouse off adjusting kick down one click at a time untill it stoped all the bucking . Van now run and shifts perfect. Also a good idea is to check wire harness on motor for wires rubbed thru, found a few of those.
