Another thing --- Airbag light - help please
Old Sep 20, 2014 | 03:26 PM
funair02's Avatar
funair02
Originally Posted by alloro
I must've missed something. If the light is staying off, then what's making you think there is still a problem?
The airbag light comes on and off while driving. The incidents only happen ever 3-5 start cycles. So some days it is fine and then one day it comes on and off 10+ times.
I had it scanned and it said "passenger seat belt short to ground". So I went to the boneyard and replaced the seat belt. After 3 or 4 starts later, it came on while driving again.
Is the connector under the seat prone to failure? You would think if the connector was flakey it would do it more than it does. I have even shook and pulled on the connector and it doesn't come on.
Really strange alloro....I am stumped
Old Sep 20, 2014 | 03:43 PM
dewaynep's Avatar
dewaynep
I would imagine the wiring to the seatbelt runs under the carpeting. Maybe it has chaffed through and is intermittently shorting to ground? You may want to trace the wiring and see where it goes to see if you can find the short.
Old Sep 20, 2014 | 04:39 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Considering the randomness of the problem, I would think the problem is more likely to be a worn clock spring.
Old Sep 20, 2014 | 09:43 PM
funair02's Avatar
funair02
I have a new one installed and actually tried TWO of them
Old Sep 20, 2014 | 09:47 PM
funair02's Avatar
funair02
Grrrrr- yea I know that is what I probably will have to do...
I did get it to act strange today...
I took the fuses out...got the light (and I should)
I swapped the two 20s Amp around --- turned on -- got the airbag light immediately (werid)
then swapped the 20s back to their ordinal location, no light...
Then on the way home, I got the light twice...probably with the same error (I wont be able to scan it again till Monday)
I am thinking either
1. chaffed wiring under the seat...which I doubt because the wiring is wound in nylon tape. It is rather strong and impenetrable. But, it could be...
or
2. the airbag module is actually bad...the error I am getting is actually because of a bad diode/trace/board inside the module...
its gotta be one or the other...I would think...but it really could be anything I may need to break down and go to the dealer
if anyone knows a master tech @ Dodge, if you could ask them...I will get ya a nice Christmas present if the answer is right
Old Sep 20, 2014 | 11:23 PM
alloro's Avatar
alloro
What was the condition of the contact surfaces on the back of the steering wheel, worn or good?
Old Sep 20, 2014 | 11:52 PM
funair02's Avatar
funair02
Nice! Nothing alarming.
FWIW my van has no rust, no rot and is as clean as it should and can be...
Old Sep 22, 2014 | 03:57 PM
funair02's Avatar
funair02
So we went on a 100 mile trip yesterday fully loaded with friends...
No light at all...
weird eh?
Old Sep 22, 2014 | 07:39 PM
MarkofCain's Avatar
MarkofCain
No light at all...
weird eh?
So, is the front passenger seat empty when the light comes on? or has it been a combination of both empty and adult filled?
What I am getting at here is that perhaps the weight or lack of weight in the front passenger seat is a contributing factor.
Old Sep 23, 2014 | 07:37 AM
funair02's Avatar
funair02
no pattern here...thanks for the idea though
Now I have gone for 150 miles with no light....
