1996 dodge does not crank
Old Jan 27, 2015 | 04:56 PM
k2nepal's Avatar
k2nepal
Default 1996 dodge does not crank
Well perhaps I need a new vehicle: I have another issue with my 1996 dodge
2500: 3.9, did put a new fuel pump, I drove it for a while, parked and not cranked, nothing, sat for 30 minutes or so, did start. Any advise ?
thank you
Old Jan 28, 2015 | 03:44 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
By "not crank" do you mean it won't start or do you mean the engine doesn't turn when trying to start it.
Old Jan 28, 2015 | 12:49 PM
k2nepal's Avatar
k2nepal
Not crank= not motor running: I have this issues for long time, go away come back again; I did change the started about three years ago. Do not start= motor running. On mine other issue with the ABS, I did pull out the ABS Controller Module: the fuse is ok now,, I have my back lights and stop lights working.Well, I am looking into others sources for more information and learning on how to located active short circuits.
Thank you and be safe
