3500 van ac no ground
Old Apr 20, 2015 | 08:07 PM
Bsodnot's Avatar
Bsodnot
Default 3500 van ac no ground
Please help ac was running great on road trip and now does not blow cold. Pressure is 45 low 150 high clutch does not enengage. I can jump 30 and 87 and clutch will run. I can also ground the high pressure switch and it will engage. Replaced high and low switch no go. Since I'm not getting ground I replaced the pcm. Still no clutch engage. Any ideas please help.
Old Apr 20, 2015 | 08:30 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Could be a break in the circuit for the high and low pressure switches and the compressor relay coil.
Old Apr 20, 2015 | 10:31 PM
Bsodnot's Avatar
Bsodnot
Any suggestions on how to test?
Old Apr 20, 2015 | 10:45 PM
Bsodnot's Avatar
Bsodnot
Any suggestions how to test
Old Apr 21, 2015 | 12:13 PM
alloro's Avatar
alloro
How good are your electrical skills? All you need really is a wiring diagram for your van and a test meter.
Old Apr 21, 2015 | 12:44 PM
Bsodnot's Avatar
Bsodnot
I have not been able to find the right diagram. Tried Haynes and all data. Using a volt probe is how I found its a ground issue.
Old May 1, 2015 | 04:30 PM
Bsodnot's Avatar
Bsodnot
Default ac clutch switch 55036447
I found its the ac clutch switch but they don't make it any more any idea how to make this work
Old May 2, 2015 | 10:23 AM
alloro's Avatar
alloro
The switch on the dash?
Old May 2, 2015 | 10:49 AM
Bsodnot's Avatar
Bsodnot
It's under the hood pasanger side in the upper blower box. It's a probe that goes in the evaporator. The dodge part number is 55036447.
Old May 2, 2015 | 04:04 PM
blackvan's Avatar
blackvan
This is what I suspected but waited to see. The part you are referrring to is not an a/c clutch, its the evaporator core sensor.
It shuts off the compressor when the evaporator core is about to freeze up and will no longer pass air. Even if you can't but a new one, any evap core sensor from any Dodge van close to this year should work. If not, I'd try Ebay.
