Alignment question and tire observation
Old Jul 12, 2015 | 11:03 PM
funair02's Avatar
funair02
Default Alignment question and tire observation
HI all.
On my 02/3.9 109" van, I had 235/75/15XLs on it and they were nice. What was interesting that after wearing about 1/3 the way they wore fast. I did keep them inflated and rotated. I got exactly 30k miles out of that set. (edit: I do still have 5/32s or so on them so I probably would have gotten 35-40k)
So I decided to get new tires. I want 16s someday, but not today So I am trying a Load C LT235 tire all-terrain. I can tell it is a stiffer tire...well it is new. Also it doesn't seem like there is a lot of difference between XL and load C. But, I like having 15/32nds now. It rides great. I have Milestar Patagonias as rubber now.
So, what I am wondering, is I was reading the alignment section of the shop manual and it states there is a special tool for the job. It is a bracket that goes on the inside of the frame rail and pushes on the upper control arm as you adjust the bolts. Do most shops have this tool???
Old Jul 12, 2015 | 11:38 PM
primem's Avatar
primem
its probably a dealer only tool.
I have not aligned one of these vans but from the service information I have:
the upper control arms have slots to allow movement. All modern alignment machines will allow adjustment in a jacked-up position. This would allow the tech to move the upper control arm will no weight on the front suspension...so you could loosen the bolts, move the c/a to where its needed, lower and perform caster re-sweep to verify the proper placement.
So IMO, the tool is probably handy but not needed to make the adjustments.
Old Jul 13, 2015 | 06:59 PM
SteveR's Avatar
SteveR
I would phone in or drive by to check into it before booking an appointment. I went to a place here and they did not but at least they were honest. My front drivers wheel leans in a lot but they said they could only adjust the toe where I'm at... I calculated that my van is probably 350-400 lbs heavier on the drivers side due to the propane tank, 3 batteries, exhaust, and kitchen all being on the one side.
Steve
