Tranny linkage and connectors
Old Sep 17, 2015 | 01:14 PM
j404ski's Avatar
j404ski
Default Tranny linkage and connectors
How do I remove the gearshift cable and trottle valve cables at the transmission? also the electrical plugs to the neutral safety switch etc. I slide the red lock tab forward but can't pry the connector off the switch. Don't want to force it so I don't break anything. I'm on my back under the tranny and its hard to see how these connectors come apart and there's nothing in the factory manual that I can find to show me how. Thanks.
Old Sep 17, 2015 | 07:42 PM
JFloors's Avatar
JFloors
You may have already figured it out but looks to me (in my haynes manual and also looking at my van) that the shift and throttle cable's ends just snap on n pop off their levers, use something like a flat blade screw driver between the cable head and mount and gently pry it up, kinda like pulling a trailer hitch off the ball.
Unless something has changed from 1999 to your 2001
I don't think my electrical connects are exact same, mine has squeeze tabs on each side, thumb and finger squeeze the tabs and gently jiggle n pull should do it. I'm getting weaker in my older age so get creative if you have to... use a thumb of one hand and press the other with the end of the screw driver and grip the plug's casing to jiggle pull.
Old Sep 17, 2015 | 08:37 PM
j404ski's Avatar
j404ski
Thanks for the input. I did get the electrical connectors apart. But didn't try the linkage yet, got sidetracked.
