95 b2500 just dies going down the road
Old Feb 23, 2016 | 01:38 PM
goldwing1's Avatar
goldwing1
Default 95 b2500 just dies going down the road
hi all I'm confused as all get out. I have a 95 2500 conversion van 318
ok heres the skinny I just bought the van and as I'm driving it the motor just dies I pull over and try to start it right away it just turns over wait about a minute and a half and it starts then drives awhile and does it again so I have replaced in order
crank sensor drove for a week with no problems then it happened
coil drove a few days then it happened
pick-up coil drove a day then it happened
checked the auto shutdown fuse GOOD
NEED HELP OH BTW I HAVE A 94 B250 318 THAT IS A RUNNING VAN THAT I AM PULLING PARTS OFF OF TO FIX THE 95
Old Feb 23, 2016 | 03:25 PM
a1mfw's Avatar
a1mfw
When was the last time it was given a complete tune-up? It could be ignition coil or the IAC idle air control valve.
Old Feb 23, 2016 | 09:21 PM
goldwing1's Avatar
goldwing1
don't know when the last time it was tuned up completely I changed the spark plugs and oil when I first got it the ignition coil was changed a week later I haven't tried the IAC I dropped the fuel tank in the 94 that I am using for parts cause it ran like a dream someone just decided to give her a black eye with their hummer on the funny side hummer had to be flatbeded and hauled off I drove mine home after bending the bumper off the front tire
Old Feb 23, 2016 | 11:48 PM
jimbo74's Avatar
jimbo74
sounds like it could be a fuel delivery issue (fuel pump)
does it show any stored codes or CEL?
Old Feb 24, 2016 | 12:10 PM
funair02's Avatar
funair02
agreed...
Start with the easy stuff first...after that it could be ECM, weird o2 sensor, leaking injectors, clogged cat etc.
Old Feb 24, 2016 | 01:02 PM
jimbo74's Avatar
jimbo74
check your alternator and wiring also..... a friend of mine recently thought he had a bad alternator, downed his truck for 2 weeks looking for a replacement... what it ended up being, was a loose connection on the back
Old Feb 26, 2016 | 09:08 AM
goldwing1's Avatar
goldwing1
ok quick update thank you all for your advice . replaced fuel pump and the IAC drove fine for about 70 miles the it happened again I was about ten miles from home and in that distance it cut off on me three times I'm thinking maybe the computer I may be wrong HELP!!!!!!!!!!!!!!!!!!!!!!
