Is this the injector wires
Old Apr 7, 2016 | 10:48 AM
philc79's Avatar
philc79
Question Is this the injector wires
I'm trying to follow this procedure:
Is this the proper connector? First pic zoomed out from location, second pic zoomed in.
Old Apr 7, 2016 | 11:51 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
That looks like the throttle position sensor (TPS) to me.
That also looks like a carb and not a throttle body, which would mean no injectors or pressure. What year is this?
Old Apr 7, 2016 | 11:58 AM
philc79's Avatar
philc79
1991 5.2, ya, looked like the carb to me as well.
Old Apr 7, 2016 | 01:37 PM
You can see the fuel line feeding the carb in the second photo. What are you trying to accomplish?
Old Apr 7, 2016 | 01:43 PM
philc79's Avatar
philc79
First off I'm a newb, I've only worked with modern Japanese FI motorcycles. The gas tank needs to be replaced. According to my service manual. I need to release the pressure in the fuel system before removing the gas tank. I attached an image of the procedure in post #1, which states to jump wire #1, #2 too Ground, Power(5 secs) to release the pressure.
My problem is I can't find anything anywhere (this manual or online) that points exactly to where the injector wiring harness is located. I looked around the engine where I suspected (no real knowledge here) and found the plug pictured. It has 4 pins as pictured, and the bracket looks like the illustration, but, that means dick. I just want to find out where the injector wiring harness is located so I can follow this procedure and remove the tank.
Old Apr 7, 2016 | 01:50 PM
philc79's Avatar
philc79
Ya, think you're right, I just saw this image which shows the TPS which to me seems to be what I took a picture of.
Old Apr 7, 2016 | 02:22 PM
philc79's Avatar
philc79
Problem resolved.
The pictures I posted in the first thread is in fact the Injector Wire Harness plug thingymajig. I connected to ground and power as outline and I could hear the pressure released. Thanks for the help guys.
