Tire pressure question
Old May 27, 2016 | 05:53 AM
hflak's Avatar
hflak
Default Tire pressure question
On the sticker inside of driver side door of my 2002 ram van 2500, the proper tire pressure is listed as, 344 kpa/50 psi for the front and 448 kpa/65 psi for the rear! This seems ...excessive, to say the least.
this is for
LT225 75R16 D tires
Comments?
Old May 27, 2016 | 08:29 AM
rsdata's Avatar
rsdata
My '01 2500 says the same... D load range tires and a loaded van will need that kind of pressure... I switched to E load range because I tow a 5000# travel trailer and want the stiffer sidewalls E tires gives me... I run 65 front and 75 rear... I rotate about every 10,000 miles and after 45,000 miles so far, I am on track to get 90,000+ miles on my Goodyear Wrangler tires.
If you run empty all the time you might drop 10# on each tire for a softer ride... but, watch your tread wear and rotate your tires and you will find what pressure works best for you.
Old May 27, 2016 | 12:55 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
What is the Max. PSI listed on your tires?
Old May 27, 2016 | 02:03 PM
iodj44's Avatar
iodj44
Your tires sidewall gives recommended PSI, the last B3500 we owned the tire had a max PSI of 95. So 65 is not excessive what is your tires load range?
Old May 30, 2016 | 10:39 PM
funair02's Avatar
funair02
this is for
LT225 75R16 D tires
Comments?
that is what it should be
