need help with van problem possible wheel bearings
Old 07-10-2016, 05:08 PM
Ryan Shaffer's Avatar
Ryan Shaffer
Ryan Shaffer is offline
well its been well over a week and the issue has not returned.
so if it wasn't the bearings it might have been something else not right but fixed when i took it apart. possibly a kinked brake line on the passenger side was the issue.
Old 07-17-2016, 09:57 PM
stev's Avatar
stev
stev is offline
Oh, it could have been the bearings. After taking things apart and placing them back together, the washer, nut and cotter-pin presses up against the bearings to hold the disc in place. If toooooo tight, the bearings will chatter, make a grinding noise or get very hot. I usually hand tighten the nut at tight as possible, free spin the wheel, check for play and then toss on the stamped form over the nut with the cotter-pin.
Otherwise, yes there is a chance for a pinched break line too.
Having a Ram Van is a life experience in minor mechanics knowledge. It keeps you sharp on your skills.
Quick Reply: need help with van problem possible wheel bearings
