A/C Isn't Working Up Front, But Does Work In Back
Old Jun 9, 2016 | 08:10 PM
BobWellington's Avatar
BobWellington
Default A/C Isn't Working Up Front, But Does Work In Back
Hey guys,
So a local animal rescue has a 2001 Dodge Van (I think it's a 2500) that had the A/C go out in the front (no air at all), but it still works in the back. Any idea of what it could be and how I could diagnose it? I searched but couldn't find anything specifically on this issue.
Old Jun 9, 2016 | 09:07 PM
What exactly is not working? The blower or there is only hot air coming out?
Old Jun 9, 2016 | 09:47 PM
BobWellington
I was told there's no air coming out at all so I guess the blower isn't running.
Old Jun 9, 2016 | 10:31 PM
Fuse, resister, motor burned up. Start with checking those things.
Old Jun 10, 2016 | 09:36 AM
BobWellington
Thanks. I was also told today by one of the drivers: "I shut it off up front for a bit then turned it back on and let it run for a bit and it started working." Does that sound like it could be the blower going out or something else?
Old Jun 10, 2016 | 11:41 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
It can be the blower or an intermittent connection. Next time it doesn't blow tap the blower motor with a hammer and see if it starts running. If it does replace the blower. The other quick test is to check for 12v power at the motor connection with the switch on. If you have 12v then the motor is no good.
Old Jun 10, 2016 | 12:07 PM
a1mfw's Avatar
a1mfw
could be a vacuum leak also if the a/c occasionally cut's out.
Old Jun 10, 2016 | 10:26 PM
BobWellington
Alright, thanks guys!
Old Jun 11, 2016 | 04:16 PM
funair02's Avatar
funair02
Expansion valve in the front is clogged or the copper temp tube is broke...
Old Jun 12, 2016 | 05:16 PM
BobWellington
I've now been told it works on high so it sounds like a resistor. I've ordered one so I'll let you guys know if it fixes it.
