What is this?
Old Sep 7, 2016 | 10:55 PM
1990B150's Avatar
1990B150
Default What is this?
And could this be why my van is running poorly?
Disconnected here...
Runs up this way...
Ends up here
Old Sep 8, 2016 | 12:31 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Air pump tube. By pumping air into the CC it causes unburnt fuel to burn. This reduces emissions.
Old Sep 8, 2016 | 08:33 AM
Is your check engine light on?
Old Sep 10, 2016 | 09:56 AM
1990B150's Avatar
1990B150
hell yeah it is, but it's permanently on because i bypassed the ECU voltage reg.
Does the nut on the end of the pipe spin? Did mine snap in half?
Old Sep 10, 2016 | 10:13 AM
alloro's Avatar
alloro
It's supposed to spin, and yes it looks like it snapped off.
Old Sep 10, 2016 | 04:02 PM
SteveR's Avatar
SteveR
The replacement catalytic converters come with a chunk of silicone hose to join between the pipe and the new cat. There is no way you are going to fix that.
Steve
Old Sep 10, 2016 | 05:28 PM
1990B150's Avatar
1990B150
Steve
You don't think I can drill out the broken part and put a new air injection pipe on? Or if the threads are damaged have someone weld on a nipple and just use hose?
Old Sep 11, 2016 | 11:09 AM
I'm sure someone could.
