thanks for the help with my trans band adj.
Old Apr 6, 2017 | 03:54 PM
Someday69's Avatar
Someday69
Default thanks for the help with my trans band adj.
Well I finally got my hands on the 8 point - 5/16'' socket..
It fit my front and rear band adj. bolts..(on mine there both just square heads, no t40 on the front)..
Well I was able to use my inch lb. torque wrench, to tighten the front to 72''lbs-- then 2 and 7/8 turns back out. (I think I ended Up with 3....
and rear band to 72''lbs and 2 turns out...
It was hard to hold the bolt tight and tighten the lock nut...but I did my best...
Now all I have to do is pour the trany fluid back down the trans dip stick tube..
Hope it works better..it's raining so I still need to replace the fluid and test dirve it..IF it works good now, I'll drive to the alignment shop...
Old Apr 6, 2017 | 08:42 PM
JFloors's Avatar
JFloors
Glad you were able to figure it out and git er done Someday69
I had the same trouble holding the screw while tightening the nut too when doing mine. I guess start with the screw backed off just a touch of adjustment mark and let the 3/4 nut draw it in close to correct mark while tightening.
Old Apr 7, 2017 | 09:26 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Let us know if it drives better than last time after you fill it up.
Old Apr 7, 2017 | 11:53 AM
Someday69's Avatar
Someday69
YEA !!! It's working again...Ya'hoo-- I'm taking it in for alignment today, Then I hope to run it through it's pace's, and find any clunks or squeaks, or whatever...I know that it has loud tire noise, So I will rotate the tires..
Anyway the trans is back! And working again...Hey it's got 145,000 miles on it, and the shift lever doesn't seem to work like new, hey I can deal with that...the differential seems ok...Maybe it needs two drive line universal joints, I can do that...right now, it off to the les schwab for Alignment...
Thanks for all the help, it's good to have people '' in your corner''----
