trans cooler check valve / replace radiator?
Old Apr 10, 2017 | 06:27 PM
Someday69's Avatar
Someday69
Default trans cooler check valve / replace radiator?
Just watched utube vid where a trany was burnt because check ball stuck in the cooler line.
It said if you have crysler you need to change the radiator at the same time you change the check valve....
Dose that apply to dodge too?
Old Apr 11, 2017 | 09:48 AM
iodj44's Avatar
iodj44
Not sure about the check valve but I'm someone else will chime in with a answer.
Aftermarket transmission coolers are something I recommend. I notice a reduction in engine temp
as well as tranny temp expecially during summer months, not a necessity but they don't hurt.
Old Apr 11, 2017 | 09:53 AM
Not sure what your vehicle details are (year, engine, transmission, mileage, etc), but it is a common mod on the Ram truck side to delete the check valve entirely.
https://dodgeforum.com/forum/2nd-gen...ve-delete.html
Old Apr 11, 2017 | 01:10 PM
Someday69's Avatar
Someday69
Default thanks
I'm going to pull the pan ''again'' it will be the third time on this fluid flush/ band adjust..
I'm going to replace the accumulator spring.....(when I get it)..
Old Apr 11, 2017 | 07:37 PM
Someday69's Avatar
Someday69
Yea thanks for the delete check valve thread..jketon... I spend like an hour on it..then looked under my 97 B2500 ram van....and it is so different than a truck...in fact this old van started life out as an Emergency vehicle ambulance, So who knows what kind of things are done to it...
Now I'm thinking I really need a mechanic, to help me, understand this rig..All the line's going all over under the hood...my, my, my ...it's really intimidating.
Old Apr 11, 2017 | 09:15 PM
Yeah. Sorry. Sometimes it takes a first hand look other than diagnosing over the Internet.
