engine wont crank
engine wont crank
ok so my issues all started with when the belt tensioner went out on my 2000 dodge ram 1500 conversion van the belt had sheard off abd wrapped aroubd the water pump so i replaced the water pumo and tensioner and when i went to start it up there was a loud noise like something broke so i tore the front end apart and found out the camshaft timing gear had snapped in half so i replaced the timing gears and chain set the timing and went to fire her up again and she still would not start i have checked every possible thing i could think of i have about 5 years of mechanics experiance and its got me scratching my head
If the cam turned and lost valve timing when the gear snapped, the valves could've hit the top of the pistons and bent. If this is what happened you would have no compression. Have you checked for compression in all of the cylinders?
You might be better off getting a used engine and swapping it out. The impact on the piston heads could've damaged them as well. Even if you don't see cracks in the tops of the pistons they could still be there just waiting to let go in a few hundred miles.
