Auto Trans Fittings
Old May 29, 2017 | 08:50 PM
bobwe1's Avatar
bobwe1
Default Auto Trans Fittings
I have a 2003 Ram Van 1500. Today I was messing with some stuff underneath. I noticed that the lines that connect the transmission fluid to the cooler on the bottom of the radiator are very loose within the screw on fittings. I took one off and the end of the tube is flared and the mating surface has an angle that I'm assuming is supposed to be a tight fit against the flare on the end of the tube. I can move the tube about 1/4 inch in and out, and it's real loose side to side too.
Weird thing is there has never been a leak, while I've had the truck. The previous owner had a new radiator put in by a mechanic. Is this the way they all are? I just can't figure out how this set up is sealing with so much play between what I'm thinking are the sealing surfaces?
Is this normal?
Here's a pic that shows what I'm looking at. Part A moves in/out by about 1/4 inch.
Old May 30, 2017 | 09:27 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by bobwe1
Is this normal?
Yes it's normal. The joints are made that way so they are flexible and have a lower chance of being crimped or twisted at the bends.
Old May 30, 2017 | 03:05 PM
bobwe1's Avatar
bobwe1
Weird, how do they seal? Why are there flares? Is the flare in the radiator swiveling? I just can't figure it out.
Old Jun 1, 2017 | 09:57 AM
alloro's Avatar
alloro
There is an O-ring inside of it that seals the line and allows it to still move.
Old Jun 3, 2017 | 10:31 AM
bobwe1's Avatar
bobwe1
Thanks, I hope it holds, seems kind of flimsy. All the other vehicles I've had used fittings that were rigid. Seems like Dodge re-invented the wheel on this one. Never had a problem with rigid lines.
