1997 B3500 Van : Driver Side Seat Belt Problem
Old Aug 4, 2017 | 09:38 AM
lawrence_vee's Avatar
lawrence_vee
Default 1997 B3500 Van : Driver Side Seat Belt Problem
Hi Smart Van Owners -
The seat belt was jammed. I took it out and am trying to figure out if I can fix it or maybe replacing it from an auto wrecker would be a good idea. It wouldn't retract and tension properly. There is this plastic clip that is loose that seems like it is the culprit but I don't see how it snaps back in somewhere. Really appreciate and help/advice.
Lawrence
Is it that gray plastic part that is flopping around that is the problem ?
Here is the full seat belt for context
Old Aug 4, 2017 | 09:09 PM
tjkoko's Avatar
tjkoko
You might try contacting SeatBeltPlanet.com with your inquiry.
Old Aug 5, 2017 | 10:55 AM
Gearheadpt's Avatar
Gearheadpt
Ugh! I had the same problem with my '97 B3500. I eventually had to purchase an OEM replacement off of eBay. It wasn't cheap. The part number I needed was 5fe15raz.
I found an '02 seatbelt in a wrecking yard that worked for a while but the wiring to the airbag is different. Is your 'check engine' light on?
Old Aug 5, 2017 | 03:37 PM
lawrence_vee
Gearheadpt : Hi, no, check engine light is not on. Thanks for sending the part number.
Old Aug 5, 2017 | 08:34 PM
tjkoko's Avatar
tjkoko
Your belt's part number should be imprinted somewhere visible on the retractor's cage or framework. Mine is. And for only $50 plus S&H SeatBeltPlanet.com repaired mine. I'd look into discussing your problem with them because the repair may be well cheaper than a replacement.
Fwiw I have absolutely no financial interest in SBP but mention them as a good company to work with.
