Help asap transmission problem
Old Aug 28, 2017 | 11:34 AM
Dhogan's Avatar
Dhogan
Default Help asap transmission problem
Just changed transmission filter and gasket. Cleaned pan and magnet. Put everything back. New atf4 fluided. No leaks. Transmission feeling off gear. Suggestions? And please note by what I saw in the old fluid this looks like its first transmission fluid change. And its a 98 dodge ram 2500 van
Old Aug 28, 2017 | 11:41 AM
Define "feeling off gear". That's too vague of a description.
Old Aug 28, 2017 | 11:54 AM
Dhogan's Avatar
Dhogan
Default Define off gear
From 0-40mph. Sometimes it takes a few seconds more than usual for the truck to accelerate. Reverse is almost nom existent like Im in neutral. At high speeds from 45-60 or more the engine sounds like its over accelerating and doesn't adjust. Feels like its over working itself to stay at certain speeds
Old Aug 28, 2017 | 12:00 PM
I assume it was working perfectly normal before the fluid change?
Old Aug 28, 2017 | 12:19 PM
Dhogan's Avatar
Dhogan
Default Before change
Before the fluid change it was hard to shift but everything was working fine except for one thing. From 0-40mph truck hesitated which is why I thought a fluid change might be needed
Old Aug 28, 2017 | 12:56 PM
Well, I changed the fluid and filter on my truck, and the next week had to have the transmission rebuilt. Hope yours is not going to be the same thing.
Old Aug 28, 2017 | 01:02 PM
Dhogan's Avatar
Dhogan
Default Trans rebuilt
Why did it have to be rebuilt?
Old Aug 28, 2017 | 01:14 PM
Not sure. New fluid dislodged gunk somewhere I guess. Lost second gear and OD.
Old Oct 20, 2017 | 11:40 PM
Ldpalmer8@gmail.com's Avatar
Ldpalmer8@gmail.com
Post Transmission proublem
I don't have a reply I'm new don't know how to post yet I have a question -i have a 1991b250van w/390 motor my front u- joint went out it broke apart a took out the tail section of my transmission the overdrive gear. Completely shattered my housing are the transmission 42re44re46re. A500-A518 overdrive tail section interchangeable
