4x4 van conversion
Old Oct 21, 2017 | 08:04 AM
  #61
Mike Mike's Avatar
Mike Mike
Default 4x4 van conversion
Have you looked to see if the 1998 4x4 truck parts will work on the 1999 van.
Old Oct 21, 2017 | 08:15 AM
  #62
wca_tim's Avatar
wca_tim
You can get about anything to work if you want to bad enough... :-) ...but it'll take major fab work. the van unibody rails are quite a bit narrower than the truck frame, to thin to bolt a lot of stuff to, curves downward over the front wheels rather than upward like the trucks (leaving no room for axle, springs, etc..)... The pics of the Quigley conversion posted a few days ago is probably the easiest / best way to do it, but I would want a lot more frame reenforcement to the frame and mount areas than it looks like they did (I'm kinda hard on things and tend to "overbuild" by many folks perspective)...
Note that there's more detail above earlier that almost nothing was bolt on. The 2500 and 1500 series trucks are very similar - ie the axles from those years mostly bolt right up aside from the rear spring width (2500 has 3" rear springs)... (not giving you grief, I know its been a few weeks). Time to go weld some more plating on my "frame" rails and start cutting the better axles out of the 2500... :-)
Old Nov 14, 2023 | 02:41 PM
  #63
VanLifer's Avatar
VanLifer
Default I need that roof rack
Originally Posted by Gearheadpt
Sorry. I just found this thread. I have a 1997 B3500 Quigley van. It has a 3" body lift and a Dana 40 up front. Let me know if you have any questions.
Nice setup, where can I get that same roof rack for my old van? I've got a 2000 1500..
