Coolant code
Old Oct 4, 2017 | 10:34 AM
Me2big's Avatar
Me2big
Default Coolant code
I have a 96 b2500 with a 3.9. I am getting a code 22 ( coolant sensor) code . I have replaced the sensor with 2 different new ones and I知 still getting the code. All the wiring diagrams I find show a 2 wire sensor but mine has only one. Anyone have any clues ? I知 totally confused
Old Oct 4, 2017 | 11:40 AM
Are you sure there are not two sensors? Some have two; one for the gauge and the other for the PCM.
Old Oct 4, 2017 | 01:00 PM
Me2big's Avatar
Me2big
Default Sensor
I never new of two sensors. I do have two and I will replace the second sensor.
Thanks for the help
Old Oct 4, 2017 | 01:38 PM
BlockHeadGearBender's Avatar
BlockHeadGearBender
Code 22 is for ECT sensor voltage too low (P0117) or too high (P0118). I also show a two-wire sensor with TN/BK and BK/LB wires. The BK/LB wire is spliced into other sensor wires and goes to PCM ground.
The instrument temperature gauge has a VT/YL wire going to a one-wire engine coolant temperature sending unit with a case ground.
Old Oct 4, 2017 | 01:49 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Both sensors are located next to the thermostat housing.
Old Oct 5, 2017 | 05:36 AM
tjkoko's Avatar
tjkoko
Just an fyi a sensor communicates with the computer and a sending unit communicates directly with a gauge.
