fuel pump relay
I cant be for certain on yours, but on my 88 it is located on the firewall.. It is sometime also called an asd (auto shut down) relay.. It is usually to the right side near the battery. What it does is when key is engaged is activate the fuel pump.. hope this helps..but I'm sure others might have answers as well.. By the way it is a very common relay used in lots of applications. So take the relay with you to auto parts place..because those guys may be clueless what an asd relay is.. and just match it up to another relay. Make sure you get a heavier duty one, not a light duty
