90' B250 - Steering Wheel Adapter Hub
Old Oct 13, 2017 | 10:24 PM
cocoon's Avatar
cocoon
Default 90' B250 - Steering Wheel Adapter Hub
Hi,
I'm new to the forum, I have a Ram B250 Maxivan Roadtrek, 5.2l with 33000 miles on it, so basically new. I'm looking to help it shake the cobwebs off and upgrade it a bit. Right now I replacing deteriorated suspension and steering parts.
I'd like to install an aftermarket steering wheel to replace the OE wheel. The new leather steering wheel is a 6 bolt, but I can't figure out which hub adapters will fit. Can anybody give me a recommendation or tell me the shaft diameter and # of splines I should be looking for (36 splines 3/4" dia. ?) I read somewhere that most hub adapters for US cars from the 70s to early 90s should work, but I'm not sure if that's true.
Thank you.
Old Oct 14, 2017 | 11:43 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Call me silly, but if you want to be sure you're ordering the correct one, why aren't you popping the steering wheel off, measuring the shaft and counting the splines?
Old Oct 14, 2017 | 07:57 PM
cocoon's Avatar
cocoon
Well, I can't find my steering wheel puller, last time I used it was 15 years ago. So I figured somebody on the forum may have gone through this before, had a recommendation for a great adapter, some advice to offer before I dig in.
