99 1500 van 5.9L loud noise coming from carb, gets up to about 30mph then decelerates
Old Nov 13, 2017 | 03:27 AM
Tennessee Jed's Avatar
Tennessee Jed
No prob starting, idles fine... there's a point on the gas pedal where I'll feel it start to lose power, then the 'howling' sound eminating from the carb barrels...changed the fuel pump about 2 months ago...could it be related? Any help greatly appreciated!
I've been told that it could be catalytic converter?
Ok... it's funny because I just looked up 'signs of converter failure' and that's what they suggested, too. Much appreciated!
Disconnected the front 02 sensor....still getting the groan when I got that spot... that's only in D, stationary. I'm going for a spin around the block to see what it does under a load.
Old Nov 13, 2017 | 10:50 AM
Try removing the front O2 sensor from the exhaust pipe. See if it runs any better.
Old Nov 15, 2017 | 03:16 PM
Tennessee Jed
Default Not much change...25mph instead of 20
I can feel a slight bit more power, but still doggin it.
Old Nov 15, 2017 | 03:26 PM
Recheck fuel pressure.
Whens the last time it had a tuneup? Does the Check engine lite start flashing at you when it starts doggin?
Old Nov 15, 2017 | 03:58 PM
Tennessee Jed
Didn't have a check engine light until I disconnected the sensor... I changed the plugs when I did the fuel pump... about 2 months ago. It was running strong...the new pump really made a difference...it sounds like the carb is sucking for air...idles and starts no problem... I'm going to try to record the noise and post it if possible.. thanks again.
Old Nov 15, 2017 | 03:59 PM
Tennessee Jed
And light does not flash.
Old Nov 15, 2017 | 06:29 PM
Think I would try and test the TPS as well.....
