Cylinders 1 and 2 Misfire Caper
Old Mar 13, 2018 | 08:53 PM
JFloors's Avatar
JFloors
This site is helpful and made simple even for guys like me. Read through this article ( 3 pages) nstructions and with a simple multimeter you should be able to verify whether the crank sensor is doing it's job...
http://troubleshootmyvehicle.com/chr...gnostic-test-2
Old Mar 13, 2018 | 10:27 PM
JC2000's Avatar
JC2000
Right. Thanks for this. The test appears to be a good test for diagnosing a cranking-not-starting issue though.
I'm curious if there's a way to test a sensor's overall performance to make sure that it's doing it's job accurately 100% of the time.
Old Mar 14, 2018 | 10:06 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Originally Posted by JC2000
I recently did another compression test to be sure that compression wasn't the issue. Attached are the results. Looks like they're about 165 to 135 and the misfiring 1st and 2nd cylinders are in the middle.
Compression is good, but the condition of plugs 1 & 2 compared to the others would indicate a weak spark due to faulty plug wires or faulty fuel injectors giving too much fuel to those 2 cylinders.
