shift linkage adjustment
Old Dec 7, 2017 | 07:39 PM
rokhard's Avatar
rokhard
Default shift linkage adjustment
I have a 1990 b-250 with a 318.
Took my van in to have the shift linkage adjusted. Lately its hard to get it into park, and sometimes I have to pull on the lever to get it to start.
They said there is an either broken or bad spring in the column thats preventing it from working and adjustments wont cut it. They said I should try to find a new steering column cuz they dont know how to find the part or something.
Something about this seems off. What do you guys think? It seems like an adjustment issue to me, and I cant find anything about any spring related to the shifting lever.
Old Dec 7, 2017 | 10:15 PM
Have a look here for a bit of the steering column. Unfortunately, you are likely going to have to disassemble it to see what's broke. Getting a junkyard column might end up being cheaper/easier.
Old Dec 11, 2017 | 06:59 PM
LedZep's Avatar
LedZep
I am having a similar issue.
The van is not always sensing that it is in Park. I did already replace the Neutral Switch on the transmission. No change.
I need to move the shift lever, then put it back into Park, then it will start.
I am guessing the shift linkage is loose.
I don't think there are any springs. Simply the linkage over time has loosened. Let me know what you find.
Brian
Old Dec 11, 2017 | 07:01 PM
There are bushings on the linkage that wear out/break when they age. I think Dorman makes replacements, found in the "Help" section at your local parts store.
Old Dec 12, 2017 | 08:02 AM
rokhard's Avatar
rokhard
I found the adjustment for mine. It was simple. right next to the transmission. Loosen a nut, and pull the linkage in about about 1/8." Problem solved. My bushings looked okay.
