96 B2500 PCM Problems Help Please
Old Jan 10, 2018 | 03:20 PM
Garr411's Avatar
Garr411
Default 96 B2500 PCM Problems Help Please
nothing happens when sanner tool is pluged in. Is there a fuse or relay ?
Old Jan 10, 2018 | 03:52 PM
A good place to start would be to check the fuse.
Old Jan 10, 2018 | 06:04 PM
Garr411's Avatar
Garr411
All fuses good, has anyone had a sanner go bad due to a bad pcm? I ask cuz i replaced the bad PCM, new one worked great till now, CEL came on, still runnin good but can't ck codes even by ignition I have the actron CP9670, thats why i was hoping for a bad fuse or something like that. I'll head to auto parts store & see if theres works till then thanks
Old Jan 10, 2018 | 09:45 PM
Try another scanner.
There *should* be power on one of the wires at the ALDL. (where you plug your scanner in) I don't remember WHICH one though......
