98 B3500 46RE Kit & TC recommendations?
Old Feb 6, 2018 | 01:59 AM
torinoscj429's Avatar
torinoscj429
Default 98 B3500 46RE Kit & TC recommendations?
Hello All
Before next summer vacation, I'm going to rebuild the 46RE in my 98 Dodge Class B motorhome, B3500, 5.9 engine, 3:91 rear, weighs 9000 pounds.
It already has the TransGo TFOD kit, GM solenoid kit, Magnetek pan. These mods got me from 32,000 miles when I bought it, to now around 55,000 miles, and I can tell from the way it slides in to third, and the extra junk in the pan, that it needs a rebuild before it totally smokes itself.
I am trained to do this kind of stuff...not an active mechanic, but I've done a few three speed automatics.
I'm shopping for a rebuild kit and new torque converter. Any recommendations for brands of parts? Any brand to stay away from?
Thanks,
Gerard
Old Feb 6, 2018 | 09:28 AM
Check out these guys for some good parts kits.
Old Feb 6, 2018 | 06:35 PM
SBQ's Avatar
SBQ
Just joined the forum. Good to see others with B class RVs. Here's my ride: https://scontent.fchc1-1.fna.fbcdn.n...46&oe=5AD7F2D1
Gerald, I noticed your rear end is dually wheel? Was this a difficult conversion? Our 1995 B3500 had a rear end swap and the mechanic could not find a replacement. They managed to locate a 2003 rear end with low mileage and put it in place with minimal alterations. Just disabled the ABS and the lug nuts were just a wee tight fit on the wheel hubs. Our original diff had a 'spun' bearing which they tried to weld but broke off again, so mechanic said have to replace the whole thing.
Old Feb 7, 2018 | 12:30 AM
torinoscj429
Originally Posted by SBQ
Just joined the forum. Good to see others with B class RVs. Here's my ride: https://scontent.fchc1-1.fna.fbcdn.net/v/t1.0-9/16105509_10154704555325239_1657789575615572999_n.j pg?oh=0853fcf0f597382922a5be0279519646&oe=5AD7F2D1
On the 99-03 Xplorer 230 XLW motorhomes, it's an aftermarket kit from Arrowcraft: http://www.arrowcraft.com/products.php#kits The rearend is a non-full floating unit...does not have the big hub sticking out.
Also on these vans, the body is split like a pizza wedge on both sides, from the top of the front wheelwell to the back of the Dodge. It starts at 0 and ends at 4 inches, giving the back end an extra 8 inches in width in the fiberglass addition. XLW = Xtra Long & Wide. Then, they add the flares, and it looks somewhat normal. The rear mattress in ours is a King, 76 wide by 80 long, or convertible to two twins, making ours an XLWT.
Gerard
Old Feb 12, 2018 | 08:07 PM
wca_tim's Avatar
wca_tim
There's a really good thread in the ram truck forums that lists specific kit parts, bands, etc... and suppliers. Worth checking out. was very helpful when I ordered everything to do mine...
