Headlight switch issues, not turning on the parking lights, front and rear
Old Apr 16, 2018 | 09:39 AM
AmericanMuscle1989's Avatar
AmericanMuscle1989
Default Headlight switch issues, not turning on the parking lights, front and rear
Hi All,
The other day the headlight switch was no longer turning on the front + rear parking lights and rear licence plate light, nor was the instrument cluster dimmer working either.
Not on the 1 pull on the switch or the full pull on the switch.
The front headlights, low and high beams still work as do the brake lights.
So I looked it up and the switch failing is a common problem so I ordered a new switch.
I just tried to install the new switch, "xxxxing complicated" and finally got it together and now same result, as above, no change at all.
What can I do now guys as the dashboard is in pieces of course.
Thanks
Old Apr 16, 2018 | 09:43 AM
AmericanMuscle1989
I should add that I know all the bulbs are working as when I lock and unlock the vehicle both the front and rear parking lights come on so the bulbs are not blown, they are just not getting the signal when I try to turn the lights on.
Thanks guys, please help if you can, feeling sad here
