Aftermarket Bumper for a 1991 RamVan
Old May 10, 2018 | 08:07 PM
Poagman's Avatar
Poagman
Default Aftermarket Bumper for a 1991 RamVan
I can't find heavy duty bumper options for RamVans. You know, the kind that supports a winch and LED lights.
Will ones intended for a 1991 Dodge Truck work?
Old May 12, 2018 | 10:17 AM
Probably not. The truck actually has a full frame. The van is likely unibody. Best bet would be a mount that plugs into your 2" receiver hitch.
Old May 14, 2018 | 03:45 PM
Poagman's Avatar
Poagman
Sorry, meant "front-bumper". I see ~1" x 1" square cut-outs in the frame about 1ft from the front that I thought may be for mounting.
Old May 14, 2018 | 04:14 PM
Poagman's Avatar
Poagman
Just read it is a uni-body design with two full length U-Channels. Does that mean no big front bumper?
Old May 16, 2018 | 08:21 PM
I have seen some pretty significant bumpers hung off the front of vans....... No clue where you would get one though.
Old May 16, 2018 | 11:06 PM
SteveR's Avatar
SteveR
I took a universal truck hitch and installed it on the front of a 1987 Ford E-150. With that hitch you could remove the side plates and flip them either way to adjust for the width of the frame horns. I also cut the rear portion of the mounts off to avoid the centre link and installed some rectangular tubing in behind the bumper to stiffen things up.
Look at the 2005 through 2010 Jeep Grand Cherokee WK factory rear hitches. You could probably make something with one of them without creating a monstrosity. They just hang down and have 4 or 5 through bolts holding them on.
