squeeling noise from frint of motor,
Old Oct 24, 2018 | 05:43 PM
peppster66's Avatar
peppster66
Default squeeling noise from frint of motor,
Hi, need some advice here, just came back from a great camping trip and now when Im at idle or low speed, there is a squealing or a chirping sound coming from the front of the motor, it sure sounds like a bearing squealing, alternator was done 2 years ago, recently I did the water pump,91 month ago), and also replaced the pulley and tensioner pulley, all that's left is power steering and/or a/c pulleys.My question is when I replaces the pulleys, should I have greased the bearings???, also is there a method to test and see which one of the bearings is chirping, ?/ when the motor is running the sound comes from everywhere,,, any help would be appreciated,,,thanks,,,
Old Oct 24, 2018 | 07:58 PM
SteveR's Avatar
SteveR
You will need to remove the belt and check each bearing individually. In the end you probably have a bad tensioner so you'll need somebody to modulate the throttle while you watch the belt to see if it jumps. I would get a tensioner from the dealer if that is the problem.
Old Oct 24, 2018 | 09:02 PM
peppster66's Avatar
peppster66
Thanks for your reply, I bought the new tensioner and pulley from rockauto,, I checked it, and the pulley moves with the tensioner when the accelerator is pressed, but the belt isn’t jumping, , I’ll try again, thanks.
