Reverse takes 10 seconds to engage
Old Jul 16, 2019 | 11:28 PM
Greyson Queen-Gene's Avatar
Greyson Queen-Gene
If that's the only problem it has, think I would just learn to love it, and not worry about it.
lol I mean I don't personally mind, but I'm worried it will prevent it from passing inspection in Virginia.
Old Jul 17, 2019 | 12:27 AM
KDodge75's Avatar
KDodge75
If my memory is correct, the bands are adjustable in these. The rear band may need adjusting. There could be a leak in the reverse servo also.
Old Jul 17, 2019 | 09:34 PM
ElkCon's Avatar
ElkCon
Originally Posted by Greyson Queen-Gene
Oh interesting i didn't know that it didn't circulate in park, but now that I think about it, it makes perfect sense.
I'm definitely not the original owner, nor was the person who sold it to me. I'm not sure how recent of a problem it is because the previous owner only owned it for a couple months before having to sell it to pay something else off and the problem existed when he bought it. It doesn't happen in any other gear, only reverse.
If it has old tranny fluid, It needs to be changed - or even flushed. EDIT use ATF+4, not universal.
From there, it could be the shift solenoid. It is a know issue.
I have the check valve delete mod and yes it take 5 seconds to go into gear from P-R. Then when I put it into drive, it takes another 2 seconds.
Other than that, a high end scanner at a tranny shop probably can tell you what the issue is.
Old Jul 20, 2019 | 01:23 PM
Greyson Queen-Gene
Thanks all!! Definitely a lot to consider. I had already bought new trans fluid and filter before coming to this thread so I'll try replacing those first. Then the bands, then solenoids and other suggestions. Appreciate the help! ❤️❤️
Old Jul 21, 2019 | 08:12 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
The low/reverse band adjustment is inside the pan, so be prepared to do that one when you change the fluid. You'll need a 1/4" drive torque wrench.
