1994 Ram 250 van fuel tank
Old Sep 7, 2019 | 12:19 PM
killim44lr's Avatar
killim44lr
Default 1994 Ram 250 van fuel tank
Recently purchased a 1994 Ram250 van w/5.2L. According to the build sheet it has a 22 gal tank. Is larger tank available (35 gal) and is it a direct replacement? Thanks for your time.
Old Sep 7, 2019 | 08:34 PM
wca_tim's Avatar
wca_tim
I can't answer your question directly, but I can tell you from a quick look that the fuel fill is the same for your 94 and the 97 fuel tank that I just put in my 99 (NOT even remotely a direct fit in the 99 at all, but I'm guessing very close to a direct in your van). You might be able to pick up the larger 35 gal tank on craigslist (where I found... $25 with the pump module still in it) or in a salvage yard. check the straps and hangers for yours and see if they're the same on the larger tank...
Old Sep 8, 2019 | 12:37 PM
killim44lr's Avatar
killim44lr
Default 1994 Ram 250 Fuel tank
Thanks for the response. I'll check the local wrecking yard.
