Sheet metal
There is a section of metal the size of my fist rusted out , driver's side in the middle of the rocker.
I've seen other RAM Vans rusted in this same area so it must be common.
I was planning on just fiberglassing over the hole once I treat the metal but would prefer to spot weld a new section in. Grind the welds down flush then fill it in with body filler.
I don't own a English wheel to bend the metal.
Anybody got an junk RAM vans I could get a section of this metal from? Mines a 2001.
It can be anywhere from the driver's side. Just needs to fit the contour of the rocker panel.
I'll take a photo of the rust hole when I get my van back.
I did a video of doing the repair on the passenger side, you could probably use a passenger side part to fix the driver side if you can't find a driver side part.
https://archive.org/details/keyparts...ages/page/n131
