Drivers side broken locking mechanism
Old Jan 4, 2020 | 01:22 PM
Meghan G's Avatar
Meghan G
Default Drivers side broken locking mechanism
Hi Dodge Vanners!
I have an '85 Ram B250 and when I insert the key into the drivers side door it wont turn to the right. The door still opens and closes when locked/unlocked from the inside but won't unlock from the outside. It was suggested I take the lining off and take a look at the lock inside the door but sadly I don't really have a clue where to start with that...any suggestions would be greatly appreciated!!
Thanks
Old Jan 4, 2020 | 03:04 PM
Open the door, and see what it takes to remove the inner door panel. Depending on what options you have, you may need to special tools for that exercise. I would suspect it is something as simple as the lock rod fell off.
