weird brake light issue
Old Jul 9, 2020 | 02:38 PM
chuckklr98's Avatar
chuckklr98
Default weird brake light issue
Top/middle brake light works, but both side brake lights do not. Changed bulbs in both. no power to them.
2000 1500 conversion with hitop
dont know where to start on this one.
Old Jul 9, 2020 | 07:31 PM
Busted Nuckles's Avatar
Busted Nuckles
Those wires for the brake lights originate under the dash and run on the floor where the drivers feet are. They progress under the seat and run up to the top right behind the drivers door. There are connectors about 8 inches off the floor behind the door. Could be test points for you. Might be something simple as a fuse. Check both fuse boxes first.
Old Jul 9, 2020 | 09:04 PM
chuckklr98's Avatar
chuckklr98
thanks, fuses are fine. beginning to think its the turn signal switch. Apparently it goes through there too. Already changed out the brake switch. not it
Old Jul 11, 2020 | 11:52 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
The left and right brake lights run through the TS switch but the 3rd light does not, so yes it's likely a bad TS switch.
Old Jul 12, 2020 | 10:32 AM
chuckklr98's Avatar
chuckklr98
Default its fixed
Changed out the turn signal switch, and short run of wire that came with it. 160 bucks. Wish i knew what part fixed it, but it was the only switch i could find. Would have loved to only change out the 60 buck switch.
