HVAC Vaccum Check Valve Direction
Old Aug 16, 2020 | 05:41 PM
ramvan20's Avatar
ramvan20
Default HVAC Vaccum Check Valve Direction
I am working on replacing the vaccum check valve in the HVAC system right by the intake manifold. When I removed the old check valve I forgot the direction that it was setup. Can someone help me with which direction it should be. I currently have it flowing into the intake manifold. Is this correct?
Old Aug 17, 2020 | 09:16 AM
Should be an arrow on the valve, indicating flow direction. You want that pointed toward the intake manifold.
Old Aug 17, 2020 | 09:24 AM
ramvan20's Avatar
ramvan20
Perfect thank you much! Time to take her for a drive and see if my AC Blowing out of the defrost when at 1/3+ throttle is fixed.
Old Aug 17, 2020 | 07:02 PM
Moparite's Avatar
Moparite
I don't believe there is anything on the originals(mine didn't have anything). If you need replacements you can get them from NAPA.
Yes!
Old Aug 18, 2020 | 11:20 AM
ramvan20's Avatar
ramvan20
Thanks Moparite I got one from Napa as my current check valve didnt work well but it didnt have any direction on it. So I blew thru it to see which direction it should flow.
Everything back in place and good to go. Thanks!
