Do I need to bleed the ABS module?
Old Sep 11, 2020 | 04:42 PM
peppster66's Avatar
peppster66
Default Do I need to bleed the ABS module?
Hi guys, still working on the brakes on my 97 B3500, replaced the master cylinder, brakes are all done , and I just want to bleed the system, do I need to worry about the ABS module, I’m not sure if air can get trapped in there, or will it just flow through as I do the front and rear brakes?, also wanted to ask if after changing the pads on the front disc brakes if there should be a little bit of drag ? The right side spins freely,but the left only spins about one rotation after a good
hand spin. There seems to be just a slight drag, but is that normal with brand new pads? Thanks for all your help,,,,
Old Sep 11, 2020 | 04:52 PM
Shouldn't have to.....
