1996 dodge ram van with an intermiten 300/302
Comes an go: I did spark plug changed, smoke vacuum leak check, pressure check, inspected all the injectors wirings, isolated the spark plug wires, A while back the idle pulley broke, which cause some damage the the AC compressor, did change the coil, due to wire was cut in half. did a replacement coil, AC is working now. Van run ok.
Thank you and God Bless
OEM, RC12YC Champion. In 03/18/2018 181,634 installed Hughes 7725 manifold intake kit. I take care of my van real good, all the fixed are documented. If I learn how to rewire this van, I will do it. Rewiring this type of van, I believe would be expensive. I plan to keep this van until 300K.
Ty, be safe
Ty, be safe
